Louis
  • Ignition plug not tried
  • Starter motor removed it stills runs
  • Ht caps, engine dies, know that already as it is impossible for the engine to run with them in
We think we may have diagnosed the issue. The loom between the killswitch/ starter and the first connection when moved causes fluxuation in rpms at idle so we think its a bad earth between the connection and killswitch, as the battery is also draining over night. It won’t be an ecu issue as everythin else is running fine its just that loom i reckon. Will update when i have more info
