If you have a GT250R that is carb model , it uses 2 relays
  •  lights control = 4pin.  By the battery
  • turn signals = 3 pin. by the battery too.
For starting the bike ,  it will be a “golfball” shaped Solenoid that has 1x thick battery wire going straight to it.  and a 2pin plug from the harness  (CDI and switch gear triggers it)  and other side of the solenoid, has a long wire going to the starter motor.
