Reply To: 125 GV S front breaks overheating Jun 12, 2023 at 5:54 AM #10506 SimonParticipant Sounds like you need to have a good clean up & check of the caliper most likely stuck pistons & the carriage is probably stuck as well. Jun 12, 2023 at 5:54 AM #10506 SimonParticipant Sounds like you need to have a good clean up & check of the caliper most likely stuck pistons & the carriage is probably stuck as well.
