Jocelyn
  • Topics: 1
Hey, Can you possibly try again as if its “1___11____1___11___ That would be a C12 in the service manual for example, there is usually one long blink first, unless you mean it’s a C18 code for sure ? If in doubt, check out the service manual for the EFi bikes that’s been uploaded a while back at “Manuals Section” of this forum, if not, just let us know and ill reupload but i believe the links should be fine. All the best!
I don’t believe the 250cc Aquila manual is listed just the carb version. I did download a service manual for it but it is a little confusing. I have tried a million times with the blink code and get the same results. I read somewhere about bridging the connector wires under seat with a wire. Haven’t tried this yet but if all else fails and I don’t push this bike off a cliff, I will try that. Thanks for any info
