    • #13456
      Graham Walker
      How do I set-up the carburetors float level, I seem to loose fuel whilst running 10k rpm for a couple of miles. Engine stops running. Slightly open choke press restart and all good. Have fitted the fuel lines,filter and needles supplied from hyoriders club store.
    • #13457
      Hello Graham,
      Take a look at your float height….  Please observe these topics below ,  (the 1st link has a picture of float height for our carbs)
      The carb float tangs are very easy to get things wrong , so you want this ….
      • Carb Upside down with floats facing the sky ^  , about 7.00mm-7.5mm max
      • Carb  Floats facing the FLOOR  (diaphragm covers facing the sky) = The floats should open to about 12-15mm   (i have forgotten the factory figure but it is usually not adjusted this way but it is worth checking)   , 17mm open might be too much but could be a max limit.
      Let us know your progress!
