Viewing 4 reply threads
    • #4897
      Alan McLean
      Could someone clarify for me what the float height should be on a GV125, the service manual I downloaded lists it at 17mm but I have also seen a read it at 7mm.
    • #4900
      7mm is correct.
      17mm is human error and if you tried 17mm the bike will have big issues later.
    • #4902
      Alan McLean
      Thanks Marcel, that’s what I thought just wanted confirmation.👍
    • #6295
      Eric Ashwell
      Greetings,
      My GV250 Floats were at 8-9, but gas continually ran out the overflow (float too close to gasket and never closing needle – so 7 would be even worse.  carburetor specificationspulled the carb out…again (fun) and I pressure benched the needle and it made a tight seal, so there would have been no reason for fuel to pour through bowl unless floats never rose to close.  I set them at 17 per manual and it won’t even start (too far away and not allowing bowl to fill before closing needle).  Is it a typo in manual (see attached)?
      Is there a happy place..I’m thinking 12-14…?
    • #6300
      Hey ,
      Have you considered that it may be that the spring-loaded valve that’s under the float is defective ?  It generally bounces back quickly when pushed by hand.
      If the spring mechanism is damaged, it will mean the whole fuel valve assembly under the float needs replacing entirely or else it makes for an added stress trying to balance the float heights on the bike.
      • #6303
        Eric Ashwell
        Thanks Marcel,
        I am going to re-set the floats to the 7mm “above” the gasket level per your recommendation, and I have considered that the actuator in the needle was stuck but I had replaced them, and checked that the little spring actuator  was working.  This bike had sat for 10 years when I bought it and I replaced most items and soaked everything in Berryman’s, but there were 2 components in each carb I plan to replace as well for the following reasons:
        1.  Float assembly – I have a feeling the float seams were cracked or otherwise compromised and after the 200km that I was able to get it run, I think they may have filled with gas and became less bouyant – I will test this theory in some hot water next time I remove the carb…OR
        2. The float needle housings – Perhaps there was some built up varnish that I was not able to clean and fresh gas loosened it to the point that the needles did not close fully or other wise were hindered in smooth operation.
        As I said, this bike sat for 10 years and I cleaned the tank, replaced the petcock, fuel lines, filter, pump, carb gaskets, idle mixture o-rings, main jets (front and rear sized right), idle jets, float needles, carb filters, needle housing o-rings, and thoroughly cleaned the carb.  It ran for 200km (performing progressively worse) and then I figured to adjust the floats.  So I think I am sooooo close!  Considering it did run at first, that 7mm must be correct.
