Both GT125R  (05-2012) to GT125RC (new shape models circa 2013/2014-2022) are all carb models.
In a nut shell
  • Same Engine. Same Speed.
  • Newer Model has smaller flywheel & custom made by Korea (it requires specific stators)
  • Regulators = Old Gen has smaller & New Reg a bit bigger = For 125cc it is the 2nd annoying electric object after the side stand switch.
  • RC = All new harness , not backwards compatible with old gen clocks  or old gen harness
  • RC = Dash has white face dials and orange LCD/White LCD   (Old Gen = Jet Black clocks all over with GREEN Letters)
  • RC = Rear Subframe is slimmer, only accepts new gen plastics and new gen seats.
  • RC & Old Gen = Both front frames have the same mounting points for headlight cages ( you can use old or new face )
  • RC Face = Accepts only diamond shape headlight & has its own brackets to link to the lower panels  (doesn’t accept old gen brackets)
  • RC Lower Panels vs Old Gen Lower Panels  (the big ones hiding the engine) == They are identical
  • RC Engine = Slightly slower  (82mph indicated brand new)
  • Old Gen Engine = Slightly more beefier , Grey Colour, has BIG DADDY style cam tensioners behind each engine  = 88 max indicated  (78-82 gps- ish…. )
  • Old vs RC = Same carbs since 2005
  • Same Fuel Pump
  • RC = Has weaker KYB Shock.    Use old Gen shock. it is much better built.
  • Old Gen = Swingarm paint survives a little better but both bikes will love you if you get them a hugger and also get their swingarms powdercoated.   Paint wise, the swingarms are the weakest but then again , wettest area on bike too! 🤐
  • RC Engine = Does not tolerate bad mods or weak batteries / reg  or fouling plugs or carbs = It will refuse to start or take ages cranking… Meticulous thing it is…
  • Old Gen Engine = Doesn’t like bad behavior from mechanics you give her to , but it will “try to start” and get you home but will be in a mood the next day.
  • Both Engines have 8 valves and they like their clearances checked every 4k miles as per korea or they actually force themselves to drop the overall top speed & they accelerate slower.
  • Both are big girls,  they like stronger 520 chain kits,  less chance of snapping as 428 chains stretch easy  (cost cutting for mass produced bike that’s all as a good 520 costs more than 428)
  • Again both big girls, make sure clutch is good or pimp out 🙂    (some owners ignore this and 20,000 miles later one of their plates have popped!)
