Mar 8, 2023 at 6:07 PM
#9884
Ok so got an ecu out of France, used, but most likely good,,, tried it, same thing. No start, smell gas have spark, low sompression, 100 psi.
So either wiring harness, or 100psi not enough to start?
I thought some engines has compression relief to turn over easier… will still start, correct?
Sensors all seemed to check ok. But maybe need to replace anyway IAPx2, eng tempwrature sensor?
Or is wiring harness issue
Baffled. I think it is flooded with gas from injectors on full?
And thoughts?
