Feb 25, 2023 at 8:32 PM
#9752
Poor girl ðŸ™
Starter System
Magneto System
How handy are you with testing your meter on the coils themselves ?
- Check for primary and secondary resistance and report back
- Check the “HT Cap” on its own (remove HT cap from the coil) and check if its over or under 9,000 ohms (end to end)
Since the oil is drained. remove the bottom “TRIANGLE” that’s under the engine where drain bolt goes in.
Under the triangle should be a “Seeve” there, take it out (watch your eyes)
And see if old teeth fall out. unless you already made sure there is no floating metal bits in the engine and replace oil filter too!
