HyoSteve
  • Topics: 4
Update, checked all connectors, electrical spray, all seem ok. Still just cranks, hear a little try only if open throttle just in option as cranking.
I have spark, i am going to replace the pick up for timing in alternator case, just to see if helps, even though it looks ok, has resistance and i have spark.
I have spark, injectors spraying, have compression, it can only be timing issue, or air fuel mixture off? All sensors ohm out good, voltage correct per manual values… i wush i could just try a new ecu, no wires look shorted to ground ect, all connected…
Aarrggg any help appreciated…
