Just got the spark plugs you said to get, doing a carby soak and yeah I rember all the fuel lines xD would you know what that random spot of oil is from on the throttle pivot point ? The last pic
Blow-Bygasses that turned to mist , then oil paste (like you would see inside the airbox) but in your picture i would double check the intake rubber pipes are okay as it may have escaped through as you can see also.
So after all that .. the previous owner had installed the fuel filter upside down -_-
Happens all too often up here too! – Well done for spotting but the previous owner has probably lost my respect for such a simple thing to get wrong. i mean fuel filters usually have direction arrows, if they didn’t the base where mesh canister inside sits is the OUT flow.
