Which spark plugs do you use ?   (Exact name and part number)
Did you do any valve clearances to the engine?   Did a compression check too ?
Also check this too….
  • HT Caps = Heat makes them fail sometimes , that’s why some of us tend to use NGK caps , but you can still use another HT cap from a Suzuki bike near your country’s salvage wreckers yard or bike shop and try it again?
  • Ignition Coil = Because it is injected and model specific , the ECU wants the coils at a certain resistance to performance
    –So check  the coil for “primary resistance” and “secondary resistance” and let us know
    Eg…  24,000 ohms and 00.10 ohm.
Keep us posted!
