Sorry to keep asking questions Marcel but should there be a hole in this item (white arrow)? You mentioned a very small hole, but I can’t get cleaner or anything through it, or feel where air might come out, and I’m loathe to refit until I’m sure it’s OK.
It’s Okay, if someone falls on to this topic , they will be happy for it and for you for getting this far . Ask whatever you like!
Yes there should be a hole there…. how about this ….
Find in your house, garage or some car store . A wire for speakers.
Strip the wire until you see individual copper strands . Get one single strand , make it straight .
Then poke inside that Starting Jet , if its clear, it will literally go deep inside and stop.
Then get a carb cleaner or “air compressor” rattle can with a tiny straw , like this ……
You will hear a nice hiss down the bottom of the carb
or
if using carb cleaner, as before spray the golden jet and you will see fluid come out on the side of the silver collumn it sits on deep inside the carb 🙂
