Dec 22, 2022 at 8:11 PM
#9271
Hey , welcome!
I would say try these first;
- Check chain slack (sometimes it affects gearing while moving) slightly or more.
- Check spark plugs (for colour and show us , and also check it says CR8E only)
- Perharps the clutch plates will need changing to better ones ?
Electrical Test;
- Take a picture of the regulator under the bike and show us even also its plugs , ill see if i can do some kind of regulator upgrade for it if its producing less power for electrics
- Test the regulator when the bike is at 5000 revs , see how much voltage the battery is making
Electrical Test 2 (advanced);
- Probe the 2 pins inside each coil and tell us ohms under 200 ohms.
- Probe 1 pin and the HT wire together and tell us ohms under 40,000 ohms.
- Unscrew HT cap gently anti clockwise and test “ONLY” the HT CAP (these cause spark issues and power problems because it is made in china) = Tell us ohms under 30,000 ohms.
After that connect HT cap to coil properly by screwing it back in to the coil before you start the bike.
- Sometimes it could be a sign of a failing coil (Happens to all Hyosungs, fortunately it is not the end of the world 🙂 …)
Other;
- Check clutch cable ,maybe its pulling the clutch a little bit ? so check cable is fully adjusted well and is not trying to engage the clutch while bike is in neutral.
I hope this helps and let us know your progress. You’ve got this! 🤞
