Hi All, has anyone else come across this problem, if the bike sits for about a week without being used the fuel petcock sticks. This has happened a few times and have had to remove the tank and dismantle the petcock, just wondering if there is a permanent solution to this problem!
Have you also unscrewed the bottom of the petcock (fuel tap) , to see if there is a lot of trap and do you use RON95 or E5 fuel ? Here in UK, we usually try to advise owners not to use E10 grade fuel due to the fact it messes up fuel systems for the bike and is corossive if stood for too long , due to bare metal inside the GV tanks.
Hi Marcel, I only use E5 (BP Premium) yes checked the trap each time and always clear. I was only away for 5 day’s and it has seized up, every time it happens I strip it down but there is never any sign of a problem, really can’t understand why it happens!!!
