Nov 20, 2022 at 5:38 PM
#9099
Hi All, has anyone else come across this problem, if the bike sits for about a week without being used the fuel petcock sticks. This has happened a few times and have had to remove the tank and dismantle the petcock, just wondering if there is a permanent solution to this problem!
Have you also unscrewed the bottom of the petcock (fuel tap) , to see if there is a lot of trap and do you use RON95 or E5 fuel ?
Here in UK, we usually try to advise owners not to use E10 grade fuel due to the fact it messes up fuel systems for the bike and is corossive if stood for too long , due to bare metal inside the GV tanks.
