Ali
  • Topics: 1
Hi sorry for the late update so managed to change the O rings but the rubber/plastic manifolds are abit worn out so might look to change them, had to change the vacuum pump just stopped working and found that 1 of the slifers was stuck so had to get that sorted, so the bike starts with easy start abit of trouble and it’s idling high and then cuts out now I have got a 6mm fuel filter which I’m looking to change to 8mm and I thi k the battery is not getting charged so the magneto or voltage regulator is up next as the battery is new and I’ve changed it up for 3 days
