Nov 8, 2022 at 5:18 AM
#9030
no code. sometimes ride the red fi light will come on . When that happens it will run normal then I’ll slow down to check code and red light go’s away so I can’t check the code. I also took the injectors out and cleaned them with carburetor cleaner and I used the battery and everything To get pull setting again it’s still kind of squirt but I don’t know if it’s dumping to much fuel or what
