Gregory4paint
  • Topics: 2
I believe my gt650r has a malfunctioning injector. Are there any compatible injectors that I can get from the local parts store
Welcome to the site, sorry that you’re having an issue with your fuel system. I assume you have found the service manual for the EFi 650 , in this forum. Then tricked your ECU to display error code on the dash. Did you get an error code or how did you come to this conclusion ? Does the same issue happen if you swap injectors between front & rear cylinders ?
  no code.  sometimes ride the red fi light will come on .  When that happens it will run normal then I’ll slow down to check code and red light go’s away so I can’t check the code.  I also took the injectors out and cleaned them with carburetor cleaner and I used the battery and everything To get pull setting again it’s still kind of squirt but I don’t know if it’s dumping to much fuel or what
