Nov 7, 2022 at 10:30 PM
#9024
I believe my gt650r has a malfunctioning injector. Are there any compatible injectors that I can get from the local parts store
Welcome to the site, sorry that you’re having an issue with your fuel system.
I assume you have found the service manual for the EFi 650 , in this forum. Then tricked your ECU to display error code on the dash.
Did you get an error code or how did you come to this conclusion ?
Does the same issue happen if you swap injectors between front & rear cylinders ?
