José María
  • Topics: 1
after mining that web, i have seen the the daewoo ECU looks similar to BOSCH MSE6.0 ECU used in benelli TRK 502, maybe I can still connect it!
It has same 48-pin coupler, and many pins have the same function.
edit: i have been a little unpolite… Did you found the trouble with your bike? mine has simillar stalling, in medium RPM regime (3000-7000)
