Sep 22, 2022 at 12:11 AM
#8697
Had the same problem before it’s the air filter did you make sure that the ECU was tuned for the air pull a twin is a low end motor so the bike will pull hard off the start and sitting with no fuel flow change in the computer it will starve itself
