Jason
  • Topics: 3
The only means I have to check the electrics is with a multimeter.
Just to digress a little, the manual only shows a two bolt TPS and not a 1 bolt.  The pins appear to be upside down on the actual bike compared to the manual.
The fuel pump was replaced with a new unit.
https://www.ebay.com.au/itm/164748784383
The temperature has 3 bars on the dash.  Before replacing the coil the rear cylinder felt noticeably cooler than the front.
