Sep 11, 2022 at 12:46 PM
#8569
Needle at zero. Clutch switch bypassed. Side stand bypassed. Tested pickup coil and readings were blue wire 0.4 should be 0.6-0.9 ohm.
Green wire readings were 131.6 ohms and should be 90-110 ohms. Do you think this is the problem.
