Hi sorry I canโt seem to put a picture on. Sprocket with smooth side facing away from the engine. I did use impact driver with no chain when removing Sprocket could that have moved something. It turns over fine just no spark.
Try the replies me and simon have mentioned and report back if you checked those electric parts.
The “Hump” of the sprocket should be facing you as this is the correct orientation and the flat-side of the sprocket should face the crank case wall towards the clutch cover.
If you can’t get a picture in,ย just let us know what error the site makes or what it’s doing so i can make it better ๐ even what phone/pc is being used.
Good luck, you got this!ย – Remember it turns yes, but things that me and simon talked about are what’s cutting sparks off , unless you have a deeper issue but basics above ^ first and let us know.
