Jason
  • Topics: 3
Ok Fuel pump replaced with a new unit,  I went with an uprated Kenso unit over the stock.
Changes in the bike now:
-Idle is now higher
-It no longer is leaning out
-Power appears to be there throughout the rev range.
New issue which I didnt notice before is i have backfiring out the exhaust and  the odd miss.  I suspect that this is plug related so ne CR8E plugs are on their way.  I have also noticed that the coils aren’t earthed to the frame very well so I will clean up the rust and getter a better earth happening.
The timing is supposed to be set at 5 deg TDC how do I measure this on a bike?
