Jason
  • Topics: 3
So just an update….
I pulled the tank off and bike apart.  I had the injectors cleaned.
One of the injectors was flowing badly.  When pulled apart they had a lot of rust build up inside the feed caps.
A hose to the MAP sensor had a split at the top.
I have it back together and it no longer wants to lean out but when riding it feels like it can’t get enough fuel.  Im suspecting that the fuel pump has had it so I have another on the way.
I will update when its fitted to see if this solves the issue.
