Thank you Simon for your contribution. I will go through all my connections and look for bad contacts. In the past I have replaced one or 2 connectors, the most awkward one being the one just under the steering column which feeds the instrument panel.
However given the fact that the bike starts flawlessly at cold and only exhibit these symptoms after warming up I don’t think bad contacts would cause this particular problem. I would expect to have problems even at cold. I also am able to read all the data coming out of the ECU and am able to display all the parameters for the bike run, in spreadsheet. I have compared data coming out at when running at cold to data coming out just before a stall and I don’t see much difference in the patterns.
regards
