Aug 12, 2022 at 11:09 PM
#8347
Hello Sir
How old is the bike (total miles?)
When was its last service and specifically which oil was used on it ?
How is the brake calipers ? (2 bolts hold each caliper to the forks) (and rear holds to its carrier)
Brake cleaner inside the caliper can help and also dont forget to use some grease behind the pads to avoid pads getting stuck if they don’t slide back smoothly
How is the chain slack ?
Sometimes a very slack chain can do this.
Check the front sprocket nut isn’t loose
(Please take a pic and show us on this forum if possible)
Do you also feel like there is some kind of misfiring going on ?
Or did the dealer fit wrong plugs ?
(causing them to breake down)
Update us fella, i will keep an eye on this thread do not worry.
