Simon
  • Topics: 1
Right the fuel pump is in the tank no vac, if the are 2 connectors on the pump (blue thing) one is feed, one return the feed one connects to the speed release which is mounted on the right hand side of the engine, the small hose  connector at the rear of the tank is the overflow just goes down & out the back. If the fuel pump only has one outlet then this connects to the injector pipes. If 2 connectors on pump look for arrows this indicates in & out
