Jun 26, 2022 at 12:44 PM
#7984
I would say slippy clutch. Engine revs would climb without immediate speed increase, especially under high exceleration. How old is the oil/what oil have you used? Is clutch adjusted properly (where is biting point on clutch lever)?
https://powersportsguide.com/motorcycle-clutch-maintenance/Â Â Â Â Â Â Â Here is loads on clutch adjustments and symptoms.
