Hey welcome!
I hope you share pics of the bike when you get it on the forum,  and wish you the best life with it 🙂
I’d usually stay away from places like aliexpress for hyosung things as the general consensus on the whole internet can attest that fitting china stuff on hyosungs usually means buying twice or problems later of some sort. so i’m not sure to advise further here sadly.
However, because GV125-EFI is an entirely different animal, it shares zero parts from its older generations , so much so that even all the part numbers i know in trade all have “1234567KGZ0000”  as opposed to older hyosungs having  “12345HG0000”, cross referencing will not be easy until you yourself see the gear switch in the flesh aswell as seeing how the shift linkage works.
Hell, ive seen a chinese item with 2 magnets that basically signal each other on every gear shift until the rider stops ,  and the gear indicator is ofcourse its own LCD.
