Jun 8, 2022 at 9:15 PM
#7886
Hi Marcel, the revs rpm reading, I heard it could be an empty battery.
RPM Revs reading comes from dashboard wire that is colour “Yellow/Black” (usually) and it works by signal from these devices below (so check them)
– Stator
– CDI
– Harness (Mystery sensors inside hardness/ aka. Mystery diodes)
– Ignition Coils
Have a look at this topic below for some ideas on electrical troubleshooting and how to test parts with a meter
It is a GT250 yes but still carby, and they sometimes use same coils , caps, & regulator as GV125
Only stator / harness / switches and some other electrical parts are only for GV125 but either way it should give you some idea.
