May 30, 2022 at 7:49 PM
#7843
Hi Max, as Marcel say’s check the charging rate coming from the regulator rectifier, you can also use this method https://youtu.be/-Rqh1PXD5H4 another tell tale sign is to check the underside of the regulator they tend to blow diodes and this can be seen on the underside of the regulator.
I would also recommend changing both coils and plug cap’s as Marcel suggested.
Best of luck.😔
