Best of luck with the coils,  i do also have a suspicion that the harness should be in the list of investigation as per my previous comments.  Neutral sensor works if it says “green” on the dash.
Mind you the harness itself has mystery sensors embedded in them  (hyosung calls them diodes) and there is a strange ball diode near the front call , we call that the “igniter” , to do with the overal bike sparking system, so have something  “MANNOL TAPE” to retape the whole harness properly if you ever check the diodes are okay.  Your meter will probably have a DIODE test function on it for the mystery sensors embedded in the harness.  Hyosung hasn’t told any one how to test them , other than replacing it or replace harness.
The flat rectangular sensor that’s near rear coil section also is Neutral and rear coil.    Just a heads up.
