Hey,
Have you had a chance to test the stator ? Since no sparks will happen if this unit is dead.   Check the resistance of the coils (3 yellow plug) and also critically the “pickup sensor”
if possible, also post a picture of the stator and your flywheel and i will confirm if they match each other.
Also while at it, under 1000 ohms or 100 ohms, test each single wire from the CDI plug to the relevant wire colour that corresponds it to rest of harness.
Ie. Blue = stator , green = stator ,  black with yellow line = front ignition coil,  blue with white line, rear ignition coil , that’s just at the top of my head 🙂
