80 kmh
That is like the imfamous “can’t get past 60 mph” issue here in UK too.
I would check the following or replace;
  • Ignition coil , sometimes sparks will come out of the wires (coil arcing) , or HT cap is faulty
    These 2 parts are common failing OEM parts.
  • Spark Plugs are breaking down.  (Dying)
  • The Carb Slides are sticky  (dirt again)
  • Regulator faulty under heavy load (common), oem regulators are not great.
  • Main Jets may be clogged again
    (sometimes we clean carbs 2x before we are fully satisfied, so be ready to clean carb 2-3x time before engine is happy with result)
  • check intake pipes are not leaking air (spray carb cleaner near them)
  • spray air boxes  top of carb and air filter box  (2 boxes, for any leaks near the joints)
