I’ll give it a shot but lol but I think I read the wrong gauge for coolant the reserve coolant tank is empty any idea which coolant to get I went to halfords and they are useless they don’t know which coolant can be used with aluminium tank
I like Motul Factory Line Motorcycle Coolant, and it is usually already mixed at factory, so you pretty much have to just fill it via radiator (check level) or the reservoir unit.
The picture you uploaded, is that the rear or front cylinder head ?  Have a feeling picture is upside down so i am not able to tell.  And is the smoke coming through the exhaust header (where pipe joins to the engine block) ?
or is there a leak somewhere externally (have a short ride down the street, then let it idle, look for something wet that may drip on to the hot exhaust pipe causing the puff of smoke.   Just be cautious and no need to open anything until the engine is 100% cold, as coolant can easily burst out burning if you open either radiator or reserve caps
