May 3, 2022 at 9:48 AM
#7526
That method of Marcel works very well. Thanks a lot for this tipp!
I noticed that the slider needles are set differently and also the airscrew on the rear cylinder was only unscrewed 1 1/2 turns. Furthermore, the springs for the diaphragms have slightly different lengths.
If I now adjust the slider needles according to the forum. How far must the airsrew be unscrewed ? And both front and rear same ?
Do I still have to match the carburetors so that they run in step? If so, how can I do that without special equipment?
Thanks and regards Max
