Max
  • Topics: 1
Hi Alan,
Thanks a lot for your quality advice.
Regarding the slider needle adjustment, I havent done any modifications. Means Its the original Airfilter, normal spark plugs (new), and the two original main jets.
Does it even make sense for me, under this circumstances, to adjust slider needle?
Or would you say, I should change spark plugs, Airfilter, main jet and then do the needle adjustment?
Just for information:
I had a problem with reaching the high speed, the bike goes hardly up to 90 kph. Before I failed with the float hight adjustment. I checked the valves, the fuel filter, the fuel pump and the spark plugs (the distance was to big, that why I got new ones, bit couldnt try If that was the reason for no high speed because of the float hight fail)
Again thanks and have a nice sunday
Hasta Luego Amigo
Max
