CptPickle
  • Topics: 7
Bit of an update. I sourced a used working engine so i could moving with this. I still have the old engine so can get it all rebuilt. The oil pump failed causing a lot of damage. I will at some point get it stripped and rebuilt. Whilst the engine was out i stripped off the tape off the wiring loom, checked, cleaned and retaped the wiring loom. I removed any rusted/ siezed bolts from the frame and gave it all a general clean up.
When the working engine arrived i cleaned that as best as possible and fitted new stainless steel exhaust studs as the old studs were rusted and bent.
I fitted the engine and replaced the old vacuum lines, fuel lines, filter and removed the EGR System and fitted an EGR Blank all bought from Marcel. And fitted a new Yuasa Battery.
It’s currently running but i need to fit a new airbox as i damaged the old one when removing it 😖 and it has a fault when starting but i’m getting somewhere ðŸ‘
