So I took the fuel tank off again and after measuring the tps again, it came back at (1.34v throttle off & 0.18v throttle on) (Which is weird because it was cold again and I never modified anything since measuring it at 3.64v before) . I took off the tps lead, ripped off the electrical wiring for the sensor and played around with different leads with the throttle on and off. I swapped out the black/orange lead with the green/red lead and reversed the connections and the tps read 0.49v with the throttle off and 1.65v with the throttle on.
I tried messing around with the tps and adjusting it but I couldn’t get it past 0.71v with the throttle off.
Put everything back together and tried starting it up anyway, it wouldn’t fire up for a while but it did go occasionally but wouldn’t stay on longer than a second.
I think I might to see if I can find another sensor somewhere locally or wait for one online and try again with a new one.
The tps is a single bolt as well.
