Simon
  • Topics: 1
You can test the stator with a multimeter, the 3 yellow wires that come from the stator to a plug you need to touch the wires – pin1-pin2, pin1-pin3, pin2-pin3 you should if all well get a reading somewhere between.   . 2ohm-.9ohm on all contacts anything out of that range it’s toast.
