Feb 25, 2022 at 10:30 PM
#6936
Castrol = Change it after 500 miles. I really do hate that brand and with hyosungs Motul Ester or Silkolene Ester is a must and use them 2 forever. Open the 125 , you will come to realize its the only one that has so many bearings, cams, valves, moving parts inside compared to a primitive 125 such as a CG125 that probs will run castrol oil forever without giving a care in the world
It’s only to use whilst i change the clutch and get it up and running. Then will be changing it again along with the brake fluid. Weather should be decent enough this week end to get the clutch apart and check it all over 👍
