ill ask a few questions but if you say yes to any of them it means you verified each part and the bike should start  or ….least see sparks….
Does the wheel spin freely in neutral?
Is the neutral light on?
Is there a clutch switch behind the handlebar ? (It must be there and i wouldn’t bypass it for several reasons)
Is there a switch under the kickstand ?  (Bypass it!!!!!!) – Join wires, go crazy with tape or watch road debris kill the wires with rain water and stones.
While cranking, do you see sparks from each plug ? are they blue or yellow?
I am going to assume you followed the tutorial on clutch plates and install and checked everything inside the clutch basket before cranking the bike over.
