Jan 17, 2022 at 6:28 PM
#6821
Howdy Ken!,
- What size jets are on the bike currently or are you the only owner ? (untouched original) , but either way advise us as to what size jets are on it mains and pilots
- When you press start, does the bike make any sound/buzzes ? or do any of the lights on dash or headlight go dimm (even slightest) ?
- The horn is activated directly by the switch gear and the switch gear sends the wires to the back of the bike so that it shares the same fuse as other electrics (the main 15A fuse). You can put a 12v meter there and see if you get any volt readings when you press the beep button on the switch gear ?
- You may email me if interested but we do have a carb gasket rebuilt kit on the /shop/ section of the site.
- I believe I am the third owner, but I got the bike stock, so it should be the stock jets. As for what size they are, I’m not sure, but I found this.
2. I do believe the light does go slightly dim when pressing the button, but no buzzing sounds.
3. My horn works, I was just curious as to what that “unit” was on the diagram because I couldn’t find it, and had no idea what it is.
4. I will check it out, and email you if i have questions about it,
Thank you for your help.
