Jan 3, 2022 at 8:04 PM
#6796
I have not checked valve clearance. I was really hoping to solve this without having to really crack open the block.. I somewhere between novice and amateur.
You can open the valve covers when bike is cold overnight, and see if there is any clearance on each valve head.
It’s like i will spin the crank few times to get to F (front) mark on flywheel then quickly check clearances , repeat again for R (rear mark) on flywheel.
You can still consult the service manual if the clearances are not in spec, it has the explanations on how to set them up right.
Good tip Simon!
