Hi Mike,
Ignore the fact someone used 7.2mm   (extra .2mm is extreme!), I just used their picture, it is too dark at the moment for me to fetch out a carb and take a picture, please excuse me for that.
  • Just make sure its 7.00mm like this photo shows and you should be good to go…
  • Also, lift the float, and let it go, you should hear the valves under it bounce a tiny bit, only a tiny bit!  Then the spring inside the valve isn’t totally dead. It makes for awkward fueling situations for the float if the valves are dead.
Hyosung Float Height GT125 Carb GV250 GT250 GV125
Hope this info helps.
