Dec 5, 2021 at 8:43 PM
#6715
Hi,
I finally found time to fit the parts ordered as advised above. Â The final check is float height. Am I correct that this should be 7mm with the floats resting on the needles as in the attached photo?
i have followed the advice given so far and will do the same for the final assembly. I will let you know the result.
Many thanks
Mike
