Nov 18, 2021 at 6:20 PM
#6625
If your bike I’d doing that speed at a lower rpm that also means it will go faster at 11,000rpm I agree it may not be alot but you can’t expect alot from chain and sprockets in term of top speed because your engine is still the same power ect if you are expecting noticeable changes in speed you should think about losing any unnecessary weight from the bike and put performance ait intake and bigger jets in the carbs and maybe even an exhaust so you have alot better acceleration and then alter the gearing(sprockets) further towards top speed…. The chain is the money as that is the crucial thing that has to be strong enough to handle more power than that bike can put out they are often priced on strength as that is their purpose
